NWA1123-ACv2 is operating at 100Mbps not 1000mbps.
ilove2hope
NWA1123-ACv2 is operating at 100Mbps not 1000mbps. I have 3 devices only 1 is functioning at 1GBPS lan speeds. The firmware is updated. Their connected to routers that suppoted 1GBPS. How do I correct this?
Hello @ilove2hope
Sometimes Ethernet auto speed negotiation fails.
Is there a way to set your router's LAN Ethernet port to 1000 Mbits fixed speed?
If so, then that might make the NWA1123-ACv2 work at 1000Mbits too, as according to the specifications available at https://www.zyxel.com/uk/en/products_services/802-11ac-Dual-Radio-Ceiling-Mount-PoE-Access-Point-NWA1123-ACv2/specifications it should be able to work at that Ethernet line rate.
I hope that this is helpful.
Merry Christmas and Happy New Year.
Tony0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 459 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
