USG FLEX 100W WLAM DHCP
I see under wireless the only settings are Outgoing Interface which have choices of LAN1, LAN2 & DMZ.....am I missing on option so it will not be part of those interfaces?0
The DHCP setting are in interface like LAN1 when you setup the SSID for no untag VLAN ID 1 you set VLAN support to off and outgoing interface LAN1, if setting up a VLAN on base port LAN1 for the SSID you set VLAN support to on.0
Hi @Lost1
You can choose Outgoing Interface (e.q. lan2) of WLAN.
And navigate Configuration > Network > Interface > Ethernet > Edit interface(e.q. lan2) DHCP IP range.
Thanks! Yes that's my issue/question...I want to use Lan1 & Lan2 for different things other than Wlan. It's like you only get two different networks when you use Wlan wereas my old zyxel had Lan1, Lan2, Wlan, & DMZ all with their own subnets.I just hate giving up Lan2 or Lan10
Make a new zone and a VLAN with that zone for the WLAN.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 627 USG FLEX H Series
- 352 Security Ideas
- 54 Wireless Ideas
- 492 News and Release
- 108 Security Highlight
