Dynamic VLANs for VPN clients with RADIUS server
Wojtas
Wojtas image  Freshman Member
edited July 2024 in Security Ideas
Hi All,
I have USG210, and I would like to dynamically assign VLAN to a VPN client based on RADIUS policies. Is it possible to achieve it? For this moment I have NXC2500 connected to RADIUS for 802.1x WLAN auth with dynamic VLANs and everything works good, now I would like use RADIUS for VPN clients.
0 votes
Active · Last Updated
  • jasailafan
    jasailafan image  Master Member
    What is the type of vpn client? ssl vpn client? l2tp vpn client? or zywall ipsec vpn client?
  • Zyxel_Jeff
    Zyxel_Jeff image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Thanks for your feedback.
    Currently, we don’t support this feature.
  • Wojtas
    @jasailafan
    Now I use L2PT with users stored in USG, but I can change VPN type to SSL VPN, or other  if needed. Do you have some ideas how to set it up?
  • Wojtas
    Hi, @Zyxel_Jeff
    Have you plan to implement the feature for anyone of  C2S VPN connections?
  • Zyxel_Jeff
    edited June 2021
    Hi @Wojtas
    I have moved your discussion to the Idea category, we will put your idea into our future development evaluation.
