[Release Note] SecuExtender - Software (Mac OSX) Version 1.2 has been released!
2»
  • Brad
    Brad Posts: 9
    image  Freshman Member
    @Zyxel_Charlie provided a temporary workaround.
    Once your trial expires it will prompt for the serial which allows you to enter it without issue.
    I set the date forward on my Mac and it prompted for the serial, which allowed me to register it.
  • Brad
    Brad Posts: 9
    @Zyxel_Charlie - Thank you for the fix and quick response.
  • chris78100
    chris78100 Posts: 1
    I have a 1.2.1 version of Secure Extender on my MAC M1. The trial period is over and I would like to purchase the permanent version.
    When I click on purchase, it takes me to the market place where I can only buy the 1.1.7 version which will no doubt not be supported by BigSur
    My question is simple : Where can I buy the 1.2.1 version ?
    Thanks for your help
