2 vlan on xgs1930 + internet without USG
sanio
sanio Posts: 1 image  Freshman Member
edited August 2022 in Switch
Hello
I have an internet box (without vlan management) + 1 Switch xgs1930-52. I have configured 2 vlan (vlan 1 and vlan 2) on my xgs1930-52.
The PCs in the 2 vlan must not be able to see each other but they must be able to go on the Internet.
All this without USG (router / firewall)
How should I do ?
thank you in advance
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,093
    image  Zyxel Employee
    Hi @sanio,
    Welcome to Zyxel community.
    Because your internet box without vlan management, if you use VLAN function that will make your PC which is not in the same VLAN as the internet box would not link to the internet.
    We recommend you to use port isolation to archive you propose.
    Example is shown below.
    Note:
    All VLAN port setting are used as examples in this article. Please replace them with your actual network setting.
    1.Go to Menu > Advanced Application > VLAN > VLAN Configuration > VLAN Port Setup to check port isolation you what they could not be able to see each other. Here we check port 1&2. This means port 1&2 will be isolated. They can not communicate each other but they can communicate other port which is no been isolated.
    Hope it helps.
    Zyxel Melen
