USG110 Not communicating with HTTP/S
All resources routed from this devices are working properly, ( I can load portal from my laptop normally ).
Can someone help on this issue, No IDP Signature, Firmware, Antivirus Signature is getting updated.
Devices are licensed.
Error when trying to Register: Fail to connect to portal.myzyxel.com
Error when trying to Sync NTP Time:
CLI Number: 1 Error Number: -21023 Error Message: 'NTP synchronization has timeout.' |
DNS is configured properly ( I think ) See Below:
Hi All,
Apparently having WAN1 and WAN2 activated at the same time was not allowing my devices to communicate with Zyxel Portal.
I keep both WANs active because of fail-over, but I need my signatures up to date so I had to disable WAN2.
Maybe Zyxel has to check further on this. Fail-over does not also work properly even if WAN1 is down, unless i remove the cable from port.
Thank you for your effort.0 -
I think their needs to be a option to make the USG use a set interface for communicate with Zyxel Portal and signatures up to dates.
Hi @Agron,
Can you please share some information for better understanding;
1- Did you set DNS forwarder for both wan interfaces as I mentioned above and try that?
2- Can you please test signature update when only wan1 interface is plugged and only wan2 interface is plugged?
3- Can you please go to Maintenance > Diagnostics > Network Tool > PING IPv4 and try to ping google.com both for 2 interfaces as following?
4- Can you please tell me how do you test the failover function?
5- If adding the DNS forwarder doesn't solve your problem, can you please send me your startup-config.conf by private message?
Best regards.
- 243 Nebula Ideas
- 6.9K Security
- 790 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 326 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
ZCNE Certified
