upgrade Firmware USG200
philipgoossens
philipgoossens Posts: 2 image  Freshman Member
Can we still upgrade the firmware on a USG200 (even if only upgrades for USG210 are available)?  Can we use the USG210 firmware upgrade for it, or wouldn't it work?  Currently my speed has dropped from 200 to 40 mbps what could be the reason ?
philip
  • dpipro
    dpipro Posts: 73 image  ZCNE Certified
    First Comment Friend Collector Seventh Anniversary ZCNE Switch Level 1 Certification - 2020
    The USG200 support ended and you can't use USG210's firmware, is a total different platform. I highly suggest to replace it for a new USGFLEX, it's safer and faster than your old appliance. BR
    Best regards
  • dpipro
    Best regards
  • philipgoossens
    OK thank you for your answer.
