Need NWA210AX series AP support for the "Ethernet Neighbor" function.
Ark
Ark Posts: 1
First Anniversary
image  Freshman Member
edited May 2024 in Wireless
1. There are three NWA210AX series APs. Mode - Sand alone. They have an AP function - "Ethernet Neighbor".
2. Problem - the function works strangely. When the APs connected to the usual unmanaged switch, they see each other by "Ethernet Neighbor" perfectly.
3. When APs connected to a VPN50 router or to managed switch Microtik CRS305-1G-4S, the function stops working.
4. Question - what parameters need to be set on the above equipment in order for the function "Ethernet Neighbor" to become operational using router or managed switch?
Best Answers
  • Greenlight
    Greenlight Posts: 57
    image  Ally Member
    edited May 2021 Answer ✓
    Network devices usually use LLDP packets to exchange device information with neighbor devices (which are directly connected to each other), so when those APs are connected to VPN50 or managed switch, they can't receive those information from each other (the VPN50 or managed switch learned/received the neighbor information instead).
    The reason why you can see APs in the Ethernet neighbor in case 1 is because, the unmanaged switch won't learned(received) the LLDP packet and directly broadcast it instead. so all APs can recognize each other and display other's information in the list.
    I'm not sure if there's any option that can be set on VPN50 or managed switch to let them forward LLDP packets. But base on the protocol, there should be no way. As an alternative, you can check all neighbors information on VPN50/Managed Switch(which is directly connect to all APs).
  • Zyxel_Freda
    Zyxel_Freda Posts: 397
    25 Answers First Comment Friend Collector Third Anniversary
    image  Zyxel Employee
    Hi @Ark,
    The neighbor information is come from the LLDP (Link Layer Discovery Protocol) packet, so the AP will get the neighbor's info when the neighbor supports LLDP as well.
    As Greenlight mentioned, the un-managed switch does not support LLDP and broadcast the LLDP packet, so when the other APs connected to the un-managed switch get the packet, they will reply to the AP, so there's information of the other APs in the item 2. However, if the un-managed switch is replaced to a managed switch or router/gateway which are supported LLDP, they will reply the LLDP packet to the AP to show as the neighbors on the web GUI.
    If you want to check Zyxel devices in your environment, you may use ZON to scan and the devices will show on the ZON utility. Here's the ZON download website for your reference.
    https://www.zyxel.com/tw/zh/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
  • Greenlight
    image  Ally Member
  • Zyxel_Freda
    Hi @Ark,
  • jpblanch75
    jpblanch75 Posts: 193
    First Comment Friend Collector Fourth Anniversary Community MVP
    image  Master Member
    Hi @Ark,
    So if my APs show the neighbor as my Managed Switch does that mean its not working correctly?
  • Zyxel_Richard
    Zyxel_Richard Posts: 260
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    Hi @jpblanch75
    Your AP works correctly and display the right information get from the connected managed Switch!
    Let me recap the difference mentioned by @greenlight :
    1. If AP is connected to a managed switch, it will display switch's information on the neighbor column
    2. If AP is connected to an unmanaged switch, user can't see the switch on the neighbor column
    The reason that causes the difference is on the way how switch process the LLDP packet. Where managed switch can send/receive its own information, but unmanaged switch only forwards the packet, and won't include its own information.
    Best Regards,
    Richard
