Question About Wireless VLANs w/ GS1900 Series Managed Switches
2»
  • B1ggJoe
    B1ggJoe image  Freshman Member
    Hello @Zyxel_Ryan
    Thank you again for all of your help and patience. I'm attaching a Network Diagram of what I'm hoping to accomplish.
    Please review and let me know your thoughts. I did end up purchasing additional ZyXEL switches because I realized that it would be necessary in order for me to accomplish the design on this Network Diagram.
    I stuck with the GS-1900 series, just to keep everything the same.
    Since you know the ZyXEL switches very well, please feel free to list whatever steps will be necessary for me to configure the switches accordingly.
    Thank you again!
    BJ
  • Zyxel_Ryan
    Zyxel_Ryan image  Zyxel Employee
    First Answer First Comment Friend Collector
    edited June 2018
    Hi @B1ggJoe
    According to your topology, I will recommend you to set VLANs below.
    1. For ports connected with APs and Gateway, set ports as Tagged. For example, if the port 2 connects with AP, port 2 should be Tagged in VLAN 1, 2, 3 because AP contains these 3 VLANs.
    2. For ports connected with end-devices, set ports as Untagged.
    Ryan
  • B1ggJoe
    @Zyxel_Ryan
    Thank you very much!!! Ok, will do and will be reporting back on my results.
    Thanks again!
    BJ
  • CrazyTacos
    CrazyTacos image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Hi B1ggJoe,
    I'm a little curious about your home deployment needing multiple VLANs.
    I can understand segregating IPTVs and maybe security cameras among VLANs for traffic priority... but for the WiFi as well?
    Is this perhaps to create parental control over the kids? xD
