ISP: Static Public ip (how to use it) and...what Encapsulation choose (?!)
Hi guys,
i have a problem to configure the profile inside USG60W for our ADSL provider (fastweb).
They told me i doesn't need credential for navigation and give me our (static) public ip address...
Where i should put it?
In the PPP configuration?
Surfing the web of ISP the write some guide to configure (also) zyxel modems... i should use that parameters as ISP setting... but how?
maybe (for me) is not so clear what is the relationship between Wan Interfaces and PPP profile....
help would be appreciated.
thank you
thank you
Maybe i understand... simply doesn't use PPP for connection. I have inactivated PPP and now i can surf using our static IP on Wan1...
So PPP is needed only if credential must be used to access the ISP network, right?
2 -
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
