Connection lost when sending big files
Hey,
i've got a IPSEC vpn between 2 building.
Our head office and a smaller one.
Head office: USG210
Branch Office: USG60
All our servers are at the head office. The people in the branch office make connection to the head office for there files, apps,...
If they download a big file from the server, there is no problem.
If they try to upload one (ex 60 mb), or try to save a big file the connection is lost.
Also when i try to ping with a bigger file size (ex ping #.#.#.# -l 50000 -t) then the connection is lost.
When i ping to 8.8.8.8 with 50000, it works fine.
I enabled
, but didn't change anything.
Tried to play with the mss size, but also no solution.
Any ideas?
Thanks a lot!!!
Head office: USG210
I enabled
| "Ignore "Don't Fragment" setting in IPv4 header | " | ||
Any ideas?
Thanks a lot!!!
Hi @OTADMIN,
Did you enable DPD on both site, can you disable phase 1 DPD temporarily and try it again.
HI OTADMIN, agree with Zyxel_Cooldia to disable Dead Peer Detection on the Phase 1 Gateway .
USG UI / Configuration / IPSEC VPN / VPN Gateway / <your_gateway_for_L2TP_VPN..> or <site-to-site>/ Phase 1 Settings / Advanced / Dead Peer Detection (DPD) = OFF (untick it )
The L2TP VPN client connection from your mac/pc or th eUSG's or Peer site VPN will be more connection will be stable.
( We've seen this with work consistently less desirable ISPs ....(less popular).... where the ISP service is less sought after so to speak
If you look in the USG logs on the USG you will see under IKE logs "peer connection lost" or similar......
HTH
warwickt
Hong Kong1
- 243 Nebula Ideas
- 6.9K Security
- 796 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
