Mac address filtering on ATP/USG
DiegoF
it would be very useful to be able to create security policies based on mac address objects. In Zyxel firewall there is no possibility to create mac address objects like in other vendors firewall. Is this a feature you plan to implement on your firewalls as well?
2
Why not use a switch?
Hello @DiegoF
you can configure a dedicated wireless SSID for students with an associated VLAN in a different subnet. With this configuration you can isolate the students network from the LAN and you can add security policies for them. What you think?
Best regards0 -
Hi, i'm looking for the same issue.. I need to create mac address filter on dhcp, so only authorized MAC address can connect to the lan...
You can do this in the VPN300Nazareno said:Hi, i'm looking for the same issue.. I need to create mac address filter on dhcp, so only authorized MAC address can connect to the lan...
However this does not stop DHCP from getting a IP by DHCP....0
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
ZCNE Certified
