Connect two Zywall USG60 with switch
relains
relains Posts: 5
image  Freshman Member
I have a problem which I didn't anticipate would be a problem. I have two physical locations. My ISP connected two locations by fibre switch. I don't have both physical and remote management to this device. For me it works like unmanaged switch between this two locations.
In both locations I have Zyxel Zywall USG60 with their own Internet connection, DHCP server and local network. I want to connect this two Zywall's so that certain devices can connect with each other through this switch (by firewall rules).
The problem is that I can't configure it that the both DHCP servers won't interfere with each other. Please give me a hint what is the right way to do this.
Thanks in advance and have a nice day!
  • CHS
    CHS Posts: 181
    image  Master Member
    If fiber switch just like an unmanagement switch, then you can setup your own IP address on WAN2.
    SiteA IP: 100.100.100.1, Mask: 255.255.255.252, Gateway: 100.100.100.2
    SiteB IP: 100.100.100.2, Mask: 255.255.255.252, Gateway: 100.100.100.1
    And then add policy route for them:
    SiteA: Source: 192.168.1.0/24, Destination: 192.168.2.0/24, NextHOP: WAN2, SNAT: None.
    SiteB.....vice versa
  • mMontana
    mMontana Posts: 1,509
    image  Guru Member
    IMVHO the fibre switch should be connected to WAN2 of both USG60. And a route should tell than Network 1 should be using WAN2 for reaching Network 2, and back.
  • CHS
    CHS Posts: 181
    image  Master Member
    Does ISP offers IP address to your sites which connected with fiber switch?
    You can list IP addresses in your topology, then should much easier provide advice to you.
  • relains
    relains Posts: 5
    Yea, I tried something like this but devil is in the details. I spent over 2 hours today trying to get this work with policy route and static routes and nothing works.
    No, like i said it works like unmanaged switch between those two locations. My subnets with IP address are on the diagram.
  • mMontana
    image  Guru Member
    Ok, @relains, add an overhead. Set a Private IP address on both WAN2 interfaces. Then use them as outpoint for an IPsec tunnel. Also create a trunk without WAN2 on both USG60.
    PeterUK Posts: 4,738
    image  Guru Member
    edited August 2021
    You need to setup a LAN2
    site A on LAN1 192.168.1.0/24 gateway 192.168.1.1
    LAN2 192.168.255.0/24 gateway 192.168.255.1
    site B on LAN1 192.168.2.0/24 gateway 192.168.2.1
    LAN2 192.168.255.0/24 gateway 192.168.255.2
    You then need a static route rule on site A
    Destination IP 192.168.2.0
    subnet 255.255.255.0
    You need a static route rule on site B
    Destination IP 192.168.1.0
    I think that should do it
    and you will need some firewall rules from LAN1 to LAN2 and from LAN2 to LAN1
  • CHS
    CHS Posts: 181
    image  Master Member
  • relains
    relains Posts: 5
    Thanks @CHS - that do the trick :)
