Connect two Zywall USG60 with switch
relains
relains image  Freshman Member
I have a problem which I didn't anticipate would be a problem. I have two physical locations. My ISP connected two locations by fibre switch. I don't have both physical and remote management to this device. For me it works like unmanaged switch between this two locations.
In both locations I have Zyxel Zywall USG60 with their own Internet connection, DHCP server and local network. I want to connect this two Zywall's so that certain devices can connect with each other through this switch (by firewall rules).
The problem is that I can't configure it that the both DHCP servers won't interfere with each other. Please give me a hint what is the right way to do this.
Thanks in advance and have a nice day!
  • CHS
    CHS image  Master Member
    If fiber switch just like an unmanagement switch, then you can setup your own IP address on WAN2.
    SiteA IP: 100.100.100.1, Mask: 255.255.255.252, Gateway: 100.100.100.2
    SiteB IP: 100.100.100.2, Mask: 255.255.255.252, Gateway: 100.100.100.1
    And then add policy route for them:
    SiteA: Source: 192.168.1.0/24, Destination: 192.168.2.0/24, NextHOP: WAN2, SNAT: None.
    SiteB.....vice versa
  • mMontana
    mMontana image  Guru Member
    IMVHO the fibre switch should be connected to WAN2 of both USG60. And a route should tell than Network 1 should be using WAN2 for reaching Network 2, and back.
  • CHS
    Does ISP offers IP address to your sites which connected with fiber switch?
    You can list IP addresses in your topology, then should much easier provide advice to you.
  • relains
    Yea, I tried something like this but devil is in the details. I spent over 2 hours today trying to get this work with policy route and static routes and nothing works.
    No, like i said it works like unmanaged switch between those two locations. My subnets with IP address are on the diagram.
  • mMontana
    Ok, @relains, add an overhead. Set a Private IP address on both WAN2 interfaces. Then use them as outpoint for an IPsec tunnel. Also create a trunk without WAN2 on both USG60.
    PeterUK image  Guru Member
    edited August 2021
    You need to setup a LAN2
    site A on LAN1 192.168.1.0/24 gateway 192.168.1.1
    LAN2 192.168.255.0/24 gateway 192.168.255.1
    site B on LAN1 192.168.2.0/24 gateway 192.168.2.1
    LAN2 192.168.255.0/24 gateway 192.168.255.2
    You then need a static route rule on site A
    Destination IP 192.168.2.0
    subnet 255.255.255.0
    You need a static route rule on site B
    Destination IP 192.168.1.0
    I think that should do it
    and you will need some firewall rules from LAN1 to LAN2 and from LAN2 to LAN1
  • CHS
  • relains
    Thanks @CHS - that do the trick :)
