ZyWALL USG 300 and TLS 1.2
I'm still using device USG300 with official fw 3.30(AQE.7). But now I have problem with TLS1.2, which is not yet supported. I found that exist firmware 3.30(AQE.7)ITS-WK48-r74988 for TLS 1.2 support. Can you help me, where I can get this one?
Thank you very much for your help.
Marek Pavlicek
Hello
I use USG 300 devices, and have come across TLS. I found on the forum what can be solved with firmware 3.30 (AQE.7) ITS-WK48-r74988, tell me how to get it?
Hi, is it possible to receive that firmware too for the USG300?
Im also looking to enable tls1.2 but the firmware i'm using is
ZyXEL Communications Corp.
model : ZyWALL USG 300
firmware version: 3.30(AQE.7)
BM version : 1.12
build date : 2015-01-13 16:31:42
@Mikkoy
We have released the latest firmware on the announcement.
https://businessforum.zyxel.com/discussion/4247/zywall-usg-series-v3-30p9-wk48-firmware-released#latest
Hello Zyxel, it's possible to receive the firmware for an USG100ZyXEL Communications Corp.model : ZyWALL USG 100firmware version: 3.30(AQQ.7)BM version : 1.13build date : 2015-01-13 16:30:24
Impossible to enable TLS 1.2...
Thanks!
You should look for WK48 firmware. And enable strong cyphers.
@Zyxel_Emily
Hi, is it possible to receive that firmware too for the USG1000?
We use 3.30(AQV.7)ITS-WK28-r72114.0
- 440 Beta Program
- 292 Service & License
