USG110 with WAC6503D-S access points. Limited to 100mb?
We have recently upgraded from ADSL to Fibre, so from 16mb to 350mb. Speedtest will NOT go above 100mb. If I use the ISPs router, straight away to 350mb. Tried wireless and wired; no difference. Looked at lots of settings in the USG, but nothing is jumping out at me as a throttle. Please help.....
Is LAN cable between your router and USG110 1gbps capable?
Sometimes it's just matter of check obvious things first
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
