ATP700 + 2 WAX510D: from wifi cannot reach device on LAN
Antares3000
in Security
I've a ATP700 configured with a LAN1 setted on VLAN1. I configured a SSID on a TUNNEL ON VLAN1. If i connect to Wifi, i get the right IP address (192.168.50.53) through DHCP of LAN1 (192.168.50.1) however i cannot reach other devices on LAN (for example 192.168.50.3). I cannot uderstand where is the problem. I think there is a filter on WiFi that don't let me work on devices on the LAN. But where?
Had you enabled "Layer2 isolation" function?
Hi @Antares3000
Have same issue with internal Wi-Fi on USG20W-VPN.
Clients on Wi-fi don't connect to wired clients in same Lan
Helps Security Policy to allow any from LAN1 to LAN1.
@Zyxel_Vic
In my scenario Layer2 isolation was disabled0 -
Layer 2 isolation already disabled
Intra-BSS traffic blocking already disabled
Any other idea to try?0 -
Lan to Lan allow policy didn't work too.
Hi @Antares3000
If both are disabled, supposedly the traffic should not be blocked by the device. Is this symptom only exist when devices connecting to wifi and wired devices doesn't have certain issue? Moreover, can you describe further regarding to " I configured a SSID on a TUNNEL ON VLAN1" and draw me the topology to understand more clear?
Meanwhile, can you give me your configuration file in private message so that we can help to check if any kind of configuration issue exists.0 -
If you want we can plan a connection to my pc and you can connect directly to the devices...what do you think about it?0
- 588 USG FLEX H Series
- 477 News and Release
