VLAN GS120015
Hi @GaryCA,
Welcome to Zyxel community!
You can let port 2 become a non-member port to each VLAN to complete your purpose.
Here is the example:
Hope it Helps.
Zyxel Melen1 -
Thank you very kindly.Zyxel_Melen said:Hi @GaryCA,
Hope it Helps.
My goal is to prevent one single PC from having any access to the internal LAN. Only two ports of the switch will be used, one port will be connected to the PC that I want to isolate, and the other port will be connected to an Asus wireless router.
I want the isolated PC to have access to the internet through the router, but do not want the PC to have access to any part of my LAN, either wireless or wired. I do not want the isolated PC to even be able to connect to the router or switch interface. The isolated PC should see only the WAN, not the LAN.
Will the Asus respect the VLAN and remain blind to my LAN?
Thank you for your help, I really appreciate it.0 -
Hi @GaryCA,
If your Asus wireless router support VLAN function (802.1q), you may add a VLAN to isolate your PC from any port of your LAN.
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
