USG 60 certificate transfer
Good morning,
I need to replace a completely failed USG 60.
I need to transfer the configuration and own certificate for the vpn.
I know the procedure for the configuration, but for the certificate I don't know if it is possible and how to do it.
Thanks for the reply
Hi @BlueTeam
You can double click to edit your certificate, and click export certificate with private key after entering password. When import the certificate, the password is required too.
- 242 Nebula Ideas
- 6.8K Security
- 778 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
