All devices on a wireless lan neweork can onl ping themselves and the router - EMG1702-T10A
Claudio3126
The outer is the zyxel EMG1702-T10A.
When i try to ping any devices in my wireless lan network, i get this output :
ping 192.168.1.104 PING 192.168.1.104 (192.168.1.104) 56(84) bytes of data. From 192.168.1.108 icmp_seq=1 Destination Host Unreachable From 192.168.1.108 icmp_seq=2 Destination Host Unreachable From 192.168.1.108 icmp_seq=3 Destination Host Unreachable From 192.168.1.108 icmp_seq=4 Destination Host Unreachable From 192.168.1.108 icmp_seq=5 Destination Host Unreachable From 192.168.1.108 icmp_seq=6 Destination Host Unreachable
The ping only suceed when pingin itself and the router :
itself -
ping 192.168.1.108 PING 192.168.1.108 (192.168.1.108) 56(84) bytes of data. 64 bytes from 192.168.1.108: icmp_seq=1 ttl=64 time=0.029 ms 64 bytes from 192.168.1.108: icmp_seq=2 ttl=64 time=0.042 ms 64 bytes from 192.168.1.108: icmp_seq=3 ttl=64 time=0.065 ms 64 bytes from 192.168.1.108: icmp_seq=4 ttl=64 time=0.063 ms
the router -
ping 192.168.1.1 PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data. 64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=2.92 ms 64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=3.17 ms 64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=1.05 ms 64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=1.38 ms
Tested with 3 devices, 2 linux and 1 android, and got the same output. All of them tried to ping eachother and he result was the same.All of them connected to the router via wifi. All host were up.
Output of some troubleshooting :
i tried sudo ip route add 192.168.1.104/32 via 192.168.1.1 dev wlan0 and sudo ip route add 192.168.1.104 via 192.168.1.1 dev wlan0 but this is the output :
ping 192.168.1.104 PING 192.168.1.104 (192.168.1.104) 56(84) bytes of data. From 192.168.1.1: icmp_seq=2 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=3 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=4 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=5 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=6 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=8 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=11 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=17 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.108 icmp_seq=26 Destination Host Unreachable From 192.168.1.108 icmp_seq=27 Destination Host Unreachable From 192.168.1.108 icmp_seq=28 Destination Host Unreachable From 192.168.1.108 icmp_seq=29 Destination Host Unreachable From 192.168.1.108 icmp_seq=30 Destination Host Unreachable From 192.168.1.108 icmp_seq=31 Destination Host Unreachable From 192.168.1.108 icmp_seq=32 Destination Host Unreachable
I did try some other solutions, since its a common issue, but as none of them worked, i decided make another question about it.
i was also suggested to see if my router has an option turned on that would prevent he devices to comunicaiting with eachother, allowing them to talk only o the inernet. But i dont know what to look for, and so didnt find anything relaed o it.
Hi Claudio,
I have same issue with you before, I was report to Zyxel, but they said the model is already not support anymore...0
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
