NWA210AX, NWA100AX, NWA50AX Antenna Propagation
jpblanch75
jpblanch75 Posts: 185
First Comment Friend Collector Fourth Anniversary Community MVP
image  Master Member
edited May 2024 in Wireless
Can you supply this data for me?
Would be nice if this was available to download from the support page of each AP.
 Thanks!
Best Answers
  • Zyxel_Silvia
    Zyxel_Silvia Posts: 77
    5 Answers Friend Collector
    image  Zyxel Employee
    edited February 2022 Answer ✓
    Hi @jpblanch75 ,
    Thank you for raising questions here,
    Please refer the attached file.
    Silvia
  • jpblanch75
    image  Master Member
    Thank you!
  • MonsterD
    MonsterD Posts: 3
    Third Anniversary
    image  Freshman Member
    So looking at the antenna spec files for the 210AX .. the preferred place would be the sealing instead a not exterior wall. Is this correct?
  • jpblanch75
    image  Master Member
    I would say based on the propagation you could place them on walls no problem.  I am using them that way.  You just need to know that the antenna has more gain off the front side than it does off the backside.
