Multi-home BGP
KenPaul
KenPaul Posts: 4
image  Freshman Member
edited January 2022 in Security
We have internet connection from 2 providers coming into ATP800. We have our own class C that we are pushing to both providers. Both providers see the class C but ATP800 is also pushing prefixes from other provider. How can we prevent this?
Thanks,
Ken
  • MJStar
    MJStar Posts: 37
    First Answer First Comment Friend Collector Fourth Anniversary
    Do you mean the ATP800 establishes two BGP routes to two providers and you don't want those two providers doesn't know each other's routing information? As below:
    ATP800 to push BGP info(without provider B's routing info, only ATP800's) to provider A.
    ATP800 to push BGP info(without provider A's routing info, only ATP800's) to provider B.
  • KenPaul
    KenPaul Posts: 4
    Hi MJStar,
    Sorry for the delay. Correct. ATP800 should only push the IP setup on ATP. Currently, it pushes routes from Provider A to Provider B and vice versa.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,408
    100 Answers 500 Comments Friend Collector Sixth Anniversary
    image  Zyxel Employee
    Hi @KenPaul
    Currently, we don’t support this feature.
    ATP800 would share BGP routing info to other two sites.
  • WJS
    WJS Posts: 156
    5 Answers First Comment Friend Collector Fourth Anniversary
    image  Master Member
    Although Zyxel does not support the feature,
    If provider A, B support route-map . You can use it to restrict the Route table which learned from other BGP member.
    I have the same issue before. It would work .
