Connect GS2220 with each other?
Username_is_reserved
How to connect both Switch offline together to maintain the switch without the cloud together?
Thanks j
Hi @Username_is_reserved,
Sorry, I don't quite get your point.
Do you mean you would like to manage your switchs in standalone mode(non-cloud) together on the same web GUI like the way Nebula does?
Or you have two GS2220 switches on Nebula now, but you would like to manage them in standalone mode?
Please help to correct me if I misunderstood your words.Adam
Yes. I want buy more Switch and need to Config simple thinks like a Vlan,... at once. As the Datasheed mention.Zyxel_Adam said:Do you mean you would like to manage your switchs in standalone mode(non-cloud) together on the same web GUI like the way Nebula does?
WellI found " Cluster Management " who I see the other Switch (that Pairing worked) but I dont see who i could config both together?!
The Cluster Management feature is able to make the "Manager" switch to set configuration directly on another Zyxel switch, who is managed by Manager switch.
Please check the following images:
Once finishing Cluster Management setting, we can see other switch in member list.
Click index number to directly configure another switch settings in "Manager switch GUI".
The feature offers the way to configure switch from one to the other, it cannot configure settings for both switch at the same time.Adam
Thanks so when I set an VLan ID the Master Switch will config all the other?Sorry for the stupid Question again does that work only for the same Switch like the 10 Port -> 10 Port or when I buy an (i dont know) 20,24,... Port thinks like the Vlan ID get set to?Thanks!0
Hi @Username_is_reserved,Thanks so when I set an VLan ID the Master Switch will config all the other?Cluster Management does not help switches to synchronize configuration from Manager switch to other switch. You can only manage other switch by Manager switch and access to their configuration page one by one.
Switch in Standalone mode does not have the way to configure all switches config like VLAN and port settings at one time, but Nebula (on cloud) does.Adam
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 310 Service & License
- 504 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 112 Security Highlight
