L2TP VPN Split tunnel configuration
Hi there!
I am curious about L2TP VPN and possibility to connect to it via 'Split tunnel'?
Why am I asking? I am only able to run L2TP VPN connection from Mac and Linux instances with 'Send all traffic over VPN connection' option checked.
But I don't want to use full tunnel for this kind of VPN.
Is is possible? Is there some certain settings what I have to change? Can somebody provide some manual?
Thanks to all!
Not just un-check the 'Send all traffic over VPN connection' .
You need manual add route to the tunnel interface,
1. Check the interface name of vpn by command 'ifconfig'
2. Add route,
route add -net <destination subnet> -netmask <subnet mask> -interface pppx
3. Verify the routing table
netstat -r
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
