Connection with fiber cable
I just got 2 Zyxel GS1350-6HP switches and installed a Zyxel SFP-LX-10-D SFP:s in both switches and connected a fiber cable between them. But i do not get any link between them. One of switches says that it has a link but the other one has no link at all. What could be wrong? Fiber cable damaged?
@MecomIT,
Could you please help to collect the tech-support file (Management> Maintenance) on both of switches (collect while the cable plugin) and attached/PM to me.
Also may I know how long is this fiber cable?Chris
Thanks for help. I will be at customer site next week and i will get these logs to you then0
Fiber optic internet is a data connection carried by a cable filled with thin glass or plastic fibers. Data travels through them as beams of light pulsed in a pattern. Fiber optic internet speeds are about 20 times faster than regular cable at 1 Gbps.
MecomIT said:I just got 2 Zyxel GS1350-6HP switches and installed a Zyxel SFP-LX-10-D SFP:s in both switches and connected a fiber cable between them. But i do not get any link between them. One of switches says that it has a link but the other one has no link at all. What could be wrong? Fiber cable damaged?
Hi what kind of Cable did you get? A Multi or Single Mode?I bought mine Adapter used from Ebay and did the Mistake by bought Single Mode Adapter like yours.What you need is a SINGLE MODE Cable! The have "OS..." in there name. "OM..." are the wrong one.Thankfully from my Distributor I found a cheap 50m Cable who work so for me its not a loss...0
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 79 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 909 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
