Saving ATP100 configuration files in Nebula
Hi @bedfoto,
Greeting forum,
The architecture of on-premise and Nebula is different.
There is no text configuration file.
Once disaster occur.all settings will be pull from NCC.
Kevin
Thank you for your reply, but still not sure what you mean exactly other than I would take your comment to mean that the configuration is stored on the Nebula cloud. Previously, before using Nebula, I had stored config files that were rendered useless after certain firmware updates. Just wondering what I need to worry about now. Thanks
Hi @bedfoto,
It cannot save configuration file in Nebula mode.All settings saved in Nebula.
Not need to worry about. Settings will be pull from Nebula once the device stuck .
Or What's kind of your sceniro or inquiry ? Please feel free to contact us.
Kevin
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
