Secuextender SSL con Windows 11 si disconnette
GabrieleBSI
in Security
Buongiorno, ho configurato su vari apparati USG dei miei clienti la VPN SSL.
Sui client con S.O. Win7 e Win10 installo il SSL_VPN_Client_4.0.4.0 (per windows7 32bit) e tutto funziona bene
Con l'arrivo di Windows11 il software si connette, ma se tento Desktop Remoto si disconnette.
Ci sono delle incompatibilità con Windows 11?
Grazie
Grazie
Hi @GabrieleBSI
Yes,SSL_VPN_Client_4.0.4.0 not support Win11 Now.
You could kindly use L2TP over IPsec instead of SSLVPN.
Also,Please be aware of some windows update will affect L2TP.
https://support.zyxel.eu/hc/en-us/articles/4415084375954
Kevin
Ci sono novità?
Abbiamo anche noi diversi problemi di disconnessioni0 -
Hi Kevin,Zyxel_Kevin said:Hi @GabrieleBSI
Kevin
when SSL VPN Client will be available for Win11 ?
at the moment my company's computer is set to windows 10 but some employee want to upgrade to win 110 -
Hi @Asgatlat,
We are testing the compatibility of the VPN Client with win11.
And we will update the progress ASAP.
Thanks your patience
Kevin0 -
No idea of non-binding ETA?
Anyone experiencing problems when clicking on "connect" (the connection doesn't start at all and one has toquit, eventually reboot and try several times)?0
sono passati 7 mesi dall'uscita di windows 11 e ancora non avete rilasciato una versione compatibile. Tutto ciò è inaccettabile per chi per scelta produce prodotti destinati al comparto Business. Ci aggiornate cortesemente! Grazie
Hi @DavideASN,Sorry for delay responded.We didn't suffer the issue on newly install client.Could you provide the error messages ?
Or we can arrange the remote session directly.Kevin0
- 237 Nebula Ideas
- 6.8K Security
- 743 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
