Error message not secure, https is marked out.
That's normal.Without a chain-validated certificate, it's quite usual to have this kind of message.From WAN and from LAN.1
Hi @mconwell
You can import the certificate from your Zyxel device to avoid this.
Please refer to the below KB tutorials:
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015067&lang=EN
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=003075&lang=EN
Thanks.
Thank you I will try that1
Neither of these URLs work
kb.zyxel.com is not resolved on DNS
Could you share your issue with me if you need any help?
The "kb.zyxel.com" has been offline. Please check the community FAQ or check with us if you need any information.
Zyxel Melen0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
