Next-Gen/VPN Firewall in the next 5-10 years to be
PeterUK
PeterUK Posts: 4,841
image  Guru Member
edited July 2024 in Security Ideas
All 10Gb ports
Speed test by TCP to hit 10Gb throughput
All ports
Configurable no more WAN/LAN given ports
And most importantly all models with front Console port :)
3 votes
Active · Last Updated
  • mMontana
    mMontana Posts: 1,514
    image  Guru Member
    This means rackable by default. Maybe with an USBC console port, integrating a well known serial adapter, so no modern OS will need driver to "find" an old-but-gold RS232 interface.
    The part "no WAN/LAN given ports" it's locked up to big chunks upper rank, at least 6 interface going 10.
    Anyway... a lot of RAM, ARM multicore SoC, tougher NICs with on-chip VLAN management and quite good offload from SoC about "simple" things.
    MultiCore PPPoE daemon.
