Switch que cumpla con los siguientes RFC
OscarRG
OscarRG Posts: 1 image  Freshman Member
edited August 2022 in Switch
Switch 24 Puertos PoE
Budget de PoE+ mínimo 370 W
Debe poseer todos los siguientes:  Extensiones TLS (RFC 3546), TLS versión 1.2 (RFC 5246), TLS para Syslog (RFC 5424), (RFC 6125 ), Encripcion TLS para RADIUS (RFC 6614), SSLv2 y SSLv3, RMON (RFC2819), RFC1157, RFC1215, RFC 3411, RFC 3412, RFC 3413, RFC 3414, RFC 3415, RFC 3416, RFC 3417, RFC 3418, RFC 1981, RFC 2460, RFC 2464, RFC 2711, RFC 3484,RFC 3587, RFC 4193, RFC 4861.
Debe permitir ahorro de energía apagando los LEDs aun cuando el switch está en operación.
El switch debe poseer o soportar el protocolo UDLD.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,193
    image  Zyxel Employee
    Hi @OscarRG,
    Welcome to Zyxel community!
    Thanks for asking.
    I'm checking if our switches support those RFCs and your other requirement now.
    I will update the result to you when I finish checking.
    Zyxel Melen
  • Zyxel_Melen
    edited June 2022
    Hi @OscarRG,
    Good day.
    May I know which hardware specifications are you looking for?
    If you need have 10G SFP requirement, you may consider XGS1930-28HP or XGS2210-28HP.
    The total PoE power budget of these two models are 375W.
    If you do not have 10G SFP requirement, you may consider GS1920-24HPv2 or GS2220-28HP.The total PoE power budget of these two models are 375W.
    If you have any other requirement, please feel free to ask.
    Or may you share your scenario to us so we can help to find which model match your scenario/requirement?
    By the way, I also notice that your requirement is special.
    May you pm your background to me? Thanks.
    Zyxel Melen
  • Zyxel_Melen
    Hi @OscarRG,
    Good day.
    Hi @OscarRG,
    The models I mention above support RFC 5246, RFC2819, RFC 1157, RFC 1215, RFC 3411, RFC 3412, RFC 3413, RFC 3414, RFC 3415, RFC 3416, RFC 3417, RFC 3418, RFC 1981, RFC 2460, RFC 2464, RFC4861.
    We also found that the correct name of RFC 5424 is "The Syslog Protocol", this RFC we support timestamp format.
    Since I found your requirement is special, if you need our switch support other RFC you list, you may PM me for more detail.
    Zyxel Melen
