NWA90AX - VLAN for guest SSID (only) doesn't work
Bellocarico
As per title, I have an existing router that supports VLAN I would like ultimately to disable its WiFi (as it goes up to AC only) and use the Zyxel only.
Now the issue being: the router does .q tagging and have the main WLAN on VLAN1 and the guest WLAN on VLAN 3. Extending the main SSID works ok e.g my mobile detects the SSID "v6" and can connect to it. Connecting to the guest SSID though, I do see the SSID v6 advertised but it fails the connection. This is not an authentication issue the mobile phone complains about not being able to obtain an IP address but the DHCP is certainly working on the main router as devices can connect to the old router just fine.
Any tip on where to look to troubleshoot this?
Never mind I did find the issue in the end. The main router had a minor software bug and was reporting the wrong interface number (0-3 rather than 1-4). I've figured that out and swapped port.
Hi, @Bellocarico
Welcome to the Zyxel Community!
It's glad to hear the issue is solved.
If there is another assistance that we could help with,
Please do not hesitate to contact us!
Have a nice day,
Thank you!
Best Regards,
HsinBo0
- 242 Nebula Ideas
- 6.8K Security
- 762 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
