ATP100 - Security Policy in Nebula
Hi , I need a VLAN to block all internet traffic except Microsoft OneDrive on Android tablets and Windows apps
I've done a thousand tests with the Security policies, but it doesn't seem to work.
Has anyone personally tested this setup?
Do you have screenshots of the working configuration?
Thanks in advance
Fabrizio F.
Fabrizio F.
Hi @FabrizioF
Currently, we don’t support this scenario. The App Patrol profile can only support reject action, it doesn’t support only allow some specific apps that can be passed on a firewall rule.
Zyxel_Jeff said:The App Patrol profile can only support reject action, it doesn’t support only allow some specific apps that can be passed on a firewall rule.
OUCH! What a giant feature hole!1 -
Hi @mMontanaThanks for your feedback and comment. We would consider transferring this request to our feature queue for our future development evaluation. Thanks.0
in the end I "solved" by blocking everything as much as possible, Looking at the logs I then unblocked the sites required by the OneDrive app ... at the moment it seems to work, fingers crossed1
Zyxel_Jeff said:
Hi @FabrizioF
however I seem to have understood that in on-premises mode, it is possible to change this parameter instead ...it is a bug / limitation of Nebula mode0 -
Hi @FabrizioF Thank you for your feedback. Currently, it's our design on the Nebula mode, we will put your feedback and comments for our future development evaluation. Thanks again!FabrizioF said:Zyxel_Jeff said:Hi @FabrizioF
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
