ATP 100 doesn't forward ports
october_web
in Security
Hello, everyone,
on an APT 100, I configured the NAT rules, policy control, in the log I see that an access forward was performed, but I can't reach my web server at port 80.
If I try to reach my web server internally it works.
Your windows installation have only 1 gateway, currently FreeBSD.Windows receives packets from ATP100 (at least, should) but it will ask to FreeBSD (and not to ATP 100) to deliver answers, according to the network configuration.1
Does your webserver allows access outside the local network segment?
Yes, because it is already externally accessible from another wan
Do you have two routers/Firewall?The ATP100 and the "another wan"?0
Does the APT 100 on the WAN have the WAN IP?
Do a port scan to 80
GRC | Port Authority, for Internet Port 80
Hi @october_web,
Have you enabled "NAT loopback" ?
In order to clarify issue, Please kindly provide the topology with IP address.
Thank you
Kevin0 -
So,I have two Public IP and two FirewallsI did a scan, but port 80 does not appear to be open.Enable NAT Lookup is enabled.
The public IP is 109.238.24.174
Would you please, @october_web, tell me if you have two devices for WAN connection (the ATP 100 and another device)?mMontana said:Do you have two routers/Firewall?The ATP100 and the "another wan"?0 -
Hi @october_web,
1) Did you have another device on the WAN side ?
2) Could you capture the LAN/WAN side packet ?
3) Please check internal server have port listened.
Or we can have remote session for quikly check . Thank you
Kevin
Zyxel_Kevin said:Hi @october_web,
1) Did you have another device on the WAN side ? - NO
2) Could you capture the LAN/WAN side packet ? - how can I do it?
3) Please check internal server have port listened. - port is listening
Kevin
I'm on holiday now, if I can't solve it when I get back. Thanks0
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 524 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
