USG60 - SSL VPN conect but "this connection is untrusted"
Papa
Papa Posts: 2 image  Freshman Member
Second Anniversary
Hi, I need some advice. I set up a USG60 SSL VPN, everything works, but every time I connect I get this message "This connection is untrusted. How to solve it ?
I have it for the occasional house connection.
  • mMontana
    mMontana Posts: 1,498 image  Guru Member
    The default SSL certificate of the device is signed by the device, so it's "untrustable" as default.
    The message says something like "hey, i cannot recognize this certificate". As your browser do if you don't put up an exception.
  • Papa
    Second Anniversary
    Where and how can an exception be set?
    Does the current status affect the security of the connection or not?
    I tried to download the device certificate and upload it to the PC, but no change.
  • mMontana
    edited August 2022
    A way might be install a public validated certificate to the device. Another (never tried) way is tell to  Windows correctly (is often utterly user unfriendly) to consider trustworthy the certificate (and maybe also the certification authority).
    Tough question... As encryption between your computer and the firewall the security level is equal.
    If you can remember the data presented to you by SSL VPN application and compare it time to time if it's the same, the security of the connection won't change compared to a validated certificate or defining the certificate (and maybe the CA) trustworthy from your computer.
    However... if you don't take care on what it's proposed to you and someday change... and you don't get it. Well... Something "non that nice" might be happening and you will not be aware of.
    Last but not least: the "guru" thing is due only to the number of posts. I'm not considering myself a guru and what you read are my personal opinions.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,399 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Welcome to Zyxel’s community. Just as mMontana mentioned, the default certificate is signed by the Zyxel device itself rather than the organization that is trusted by the browser, so it would appear “this connection is untrusted” message.
    Please refer to the below description from Google Chrome Help.
    But if, you would like to establish a secure connection while login the device Web-GUI from lan1 interface 192.168.1.1, you could refer to the below steps:
    2.Configuration > System >WWW> Server Certificate change to “zyxel.local”.
    3. Configuration > System > DNS > to add an address record FQDN “a.zyxel.local” with IP address 192.168.1.1.
    4.To import the certificate “zyxel.local” to PC.
    To check the managed certificates via Chrome browser.
    5. To clean browser cache and close Chrome browser.
    6. To Open Chrome browser.
    7. The PC connects to LAN1 and enter the URL https://a.zyxel.local on Chrome browser and you would see the connection is secure, as below:
    If you view the certificate, you will find its DNS name is a.zyxel.local, as below:
