is it possible to upgrade firmware v2.20 direct to v2.60 gs1900-24e
Mick
Mick Posts: 2
image  Freshman Member
Or do i have to install the previous version first?
Thanks in advance
Mick
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,242
    image  Zyxel Employee
    Hi @Mick
    Welcome to Zyxel community!
    Yes, you may directly upgrade to the latest firmware.
    Kindly remind, that the latest firmware of GS1900-24E is V2.70(AAHK.3), you can find it here.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Mick
    Zyxel Melen
  • Mick
    Mick Posts: 2
    Thanks for the answer
