Destination unreachable on DHCP renew bug
PeterUK
PeterUK Posts: 4,784
image  Guru Member
VPN300 V5.31(ABFC.0)ITS-22WK31-r104914
Start by a capture of a interface set to DHCP then disable/enable interface all is fine then go the monitor > traffic statistics > Interface Status and click renew for the interface now every time it does a request a ACK happens but the VPN300 send a ICMP destination unreachable (Port unreachable) for the ACK.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482
    100 Answers 1000 Comments Friend Collector Ninth Anniversary
    image  Zyxel Employee
    For clarify DHCP issue between client and server we need whole of the packets without filtered. (ARP/DHCP/ICMP are required)
    You may share the packets in this thread or send that to me by private message. :)
    image  Guru Member
    It seems after some testing the problem only happens with one active DHCP not many
