blocking pornographic images from google
Hi @D2IT
You can refer to the below steps:
STEP1. Configure a content filter profile with the SafeSearch option.
STEP2. Configure an SSL Inspection profile and download the certificate to your PC. Then rename the certificate file type to .p12 and import it to your PC. You could refer to this link to see how to set up SSL Inspection.
STEP3. Add a security policy to block UDP 443.
STEP4. The LAN outgoing direction security policy to apply Content filter and SSL Inspection profile.
STEP5. To search the adult-related keyword in Google and there are no related results, because they are hidden by SafeSearch.
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
