LTE firmware for SBG3600
1141516171820»
  • helgelk
    helgelk Posts: 1 image  Freshman Member
    I should also like some firmware upgrades. Unfortunately my LTE module has never worked.
    Current versions:
    Gateway: V1.00(AAKO.4)
    LTE: ALT3100_04_05_06_10_B8_LO
  • Bob_C
    Bob_C Posts: 224 image  Master Member
    Hi helgelk,
    Please check your message inbox.
    Regards,
    Bob
  • Clemens_Mohr
    Clemens_Mohr Posts: 4 image  Freshman Member
    First Comment Seventh Anniversary
    My question is not LTE related, but DSL:
    my provider switched from DSL 17a to 35b.
    is there any way to update the firmware, so that the SBG can establish internet connection?
    BR Clemens
  • Pascal
    Pascal Posts: 8 image  Freshman Member
    My current firmware is "V1.00(AAKO.9)" and the current LTE firmware is "ALT3100_05_00_02_00_81_MS". Is there any update ? Could you please send them to me ?
    Best regards,
    Pascal
  • YeK
    YeK Posts: 150 image  Master Member
    SBG series was EOL in 2020 so there is no fw/path released anymore. Please kindly understand it.
  • Ramses
    Ramses Posts: 1 image  Freshman Member
    How glad I am that I found a thread discussing this model! Old models have to be looked for as something forbidden! I will be VERY grateful if you give me the opportunity to update your device to the latest version! Dear Bob_C, send me too!😛
  • Bob_C
    @Pascal, both are the latest.
    @Ramses, check your message inbox please.
  • Pascal
    I have an issue and I would like to re-install the firmware V1.00 (AAKO.9) (or a later version if it exists). Can someone please send it to me?
    Regards,
    Pascal
  • Bob_C
    Hi Pascal,
    Regards,
    Bob
  • MRS_JUAN
    MRS_JUAN Posts: 1 image  Freshman Member
    I am kindly requesting the firmware version V1.00(AAKO.9) for the Zyxel SBG3600-N00 device.
    Could you please provide a download link or send the file directly?
    This version is required for compatibility and testing purposes. If any additional information is needed to process this request, I will be happy to provide it.
    Thank you in advance for your assistance.
