Wateproof enclosure
Greetings from the North.
I see that the Waterproof enclosure are IPX5 certified and withstand a temperature range from -20 celcius to 50 celcius.
But the APs that are compatible with this enclosure have an operating temperature from 0 to 50 celcius.
Can the APs (that originally have 0 to 50 celcius in the datasheet), be used lower than 0 celcius and even down to -20celcius when used together with the enclosure?
Thank you for your answer.0
- 236 Nebula Ideas
- 6.8K Security
- 737 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 90 About Community
- 117 Security Highlight
