Wireless functionality showing on non-wireless USG Flex 200
citizenjazz
in Security
I recently upgraded from a long running USG Flex 50 to a 200. The upgrade went well (it was mostly done manually) but an interesting thing is that I see all the functionality in the UI that would be there if my model had built-in wireless. It does not. If it's not going to pose a problem down the road, I suppose I can ignore it but it would be nice to have the interface clean of the extra options. Is there anyway to get rid of this?
Thanks.
Thanks.
Best Answers
Hi @citizenjazz,
Welcome to Zyxel community.
The FLEX200 can work as wireless controller role, so you can see wireless related settings in Web GUI.1 -
They are.With an USG40 I am managing several NWA APs. But the same options are available in another USG40 which cannot manage any of the resident APs (not compatible with the management suite).Without any compatible AP you can still design any aspect of the wireless networks (SSIDs, timings, channels, VLANs, routing). Then when any AP can access to LAN1 of the firewall, the device can be adopted and the configuration will be deployed.0
Hi @citizenjazz,
Hi,Zyxel_Cooldia said:Hi @citizenjazz,
I figured that was the case but I'm seeing options for configuring radios and APs. (It looks similar to what I have on my Zyxel NWA1123 WAPs) I'm not able to add a radio profile or SSID profile via the UI because the hardware isn't built in. But are those configuration options supposed to be there?
Thanks,0 -
Thanks for all the feedback. I guess I'll just ignore the extra options.0
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
