How do I configure the ZyWALL for a L2TP server behind NAT?
Zyxel_Charlie
Zyxel_Charlie Posts: 1,034
image  Zyxel Employee
edited April 2021 in Security
Topology:
Network Conditions:
Router WAN IP: 59.124.163.151
ZyWALL WAN IP: 192.168.10.33
Configuration on the router:
Add a NAT rule for the router.
Allow L2TP services.
L2TP server: 192.168.10.33
L2TP service: IKE, NATT, L2TP-UDP
Configuration on the ZyWALL/USG:
IPSec VPN Gateway
IPSec VPN Connection:
The local policy is the NAT public IP address.
L2TP VPN:
Assign a pool for the L2TP clients.
Create a registry key on Windows Client:
(1) Start > cmd > Enter "regedit"
(2) Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent
(3) Add a RWORD(32 bit), and name is: AssumeUDPEncapsulationContextOnSendRule
(4) Edit value as 2
(5) Reboot PC.
On Windows 10, edit in the registry and then reboot.
REG ADD HKLM\SYSTEM\CurrentControlSet\Services\PolicyAgent /v AssumeUDPEncapsulationContextOnSendRule /t REG_DWORD /d 0x2 /f
VERIFICATION:
Use a smartphone or a PC to establish a L2TP VPN connection the to ZyWALL/USG.
Configure the NAT's public IP address as the L2TP server address on the client.
  • PaoloFracas
    PaoloFracas Posts: 54
    image  Ally Member
    There is a way to use a FQDN instead of the Static IP as "Router WAN IP"?
    PeterUK Posts: 4,728
    image  Guru Member
    You use interface IP which links to what WAN IP you have for that interface
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482
    100 Answers 1000 Comments Friend Collector Ninth Anniversary
    Hi @PaoloFracas
    You can have a try to use IP 0.0.0.0 address object as "local policy" in phase2 setting.
  • PaoloFracas
    image  Ally Member
    I have checked the solution and it works.
    Thank you.
  • MiG
    MiG Posts: 2
    image  Freshman Member
    THANKS! This manual helped me to find missed required setting :)
