Firmware for ZyWALL 2 Plus
You likely have the upto date firmware
Very old the FTP server has gone support out the window you should look into a newer model.
VPN Firewall | Zyxel Networks
I'm afraid I have not the latest, because I have a release from year 2009 and, from a google search, it looks like there exists at least a release from year 2014PeterUK said:You likely have the upto date firmware
VPN Firewall | Zyxel Networks0 -
I personally doubt about 2014.According to files in my possession, latest released is "named" 4.04 XU.11, it's dated february 2011 and release notes are signed by Mr Billy Bian.Datasheet reports 10/100mbps ports, 3000 concurrent connections, less than 25MBPS of throughtput, 5 IpSec tunnels, bare AES128 support.It's old, fainting, vulnerable and venerable device. A SOHO router out of support like VPN2S has better performances, more options, less unpatched vulnerabilities and can be managed via modern browser. You love it as a museum toy? Fine by me, I have one too.Don't consider to install it. By different orders and degrees, is a really bad idea.1
Hi @lucrus,Welcome to Zyxel community. The latest firmware is 404XZ0D0.bin. i can send it in PM if you need latest firmware.We strongly recommend replacing ZyWALL 2 Plus since it is phase out and no firmware maintenance.1
You're right, the latest it's a 2011 release, but even then it's 2 years younger than the 2009 release I have.mMontana said:I personally doubt about 2014.According to files in my possession, latest released is "named" 4.04 XU.11, it's dated february 2011 and release notes are signed by Mr Billy Bian.
Fact is, it is already in production since then, I'm only supposed to take over its maintenance. It's actually doing its job, no reason to replace it (except maybe security wise, but it's only running a small LAN of trusted computers).mMontana said:Don't consider to install it. By different orders and degrees, is a really bad idea.
Please do.Zyxel_Cooldia said:The latest firmware is 404XZ0D0.bin. i can send it in PM if you need latest firmware.
I'm not in charge for that decision here, but I'll report that suggestion upstream for sure, thanks.Zyxel_Cooldia said:We strongly recommend replacing ZyWALL 2 Plus0 -
I'm pretty sure that it's doing fine: as I sad i have one of that and served as internal router (after the CPE for splitting traffic and avoid nose picking from the ISP) for 4 years from 2016 (which was already out of support and strongly suggested to not use it). I criticize Zyxel but on firewall the hardware is really resilient and reliable.
However if that device is publicly reachable in any way is like driving a car without MOT/Vehicle approval. It works, is doing what's intended to, but when I's time for police checks (certifications) or accidents (security breakouts) might unreasonable the level of hassle. Every device behind that firewall is in heftier and greater risk than with a newer one.
As the one supposed to maintenance that, you're like the car mechanic that make that car run. IMO you should not allow that because it will bring you complicity for some issues. If you maintain an equipment which is unsafe, some laws might consider you co-liable for the fallout.I'm not in charge for that decision here, but I'll report that suggestion upstream for sure, thanks.
You can still request for dated and signed exclusion of liability if anything happens under your maintenance duty about that device.0 -
It's not. At least not directly. An attacker has to hack other routers before reaching that one, and, in that case, said attacker hacking that one would be the least problem.mMontana said:However if that device is publicly reachable in any way...
Thanks for the heads up, but at least here in Italy that resembles a sci-fi by a screenplay writer used to get high during work hours... believe me, none of that is going to happen here, at least not in the somewhat smallish company I work for.mMontana said:
hi - if possible
pleas sesend me too the latest zywall 2 plus firmware - i'm in
Model
ZyWALL 2 Plus
Bootbase Version
V1.11 | 07/12/2006
Firmware Version
V4.02(XU.3) | 07/31/2007
and my purpos is only for study and test and lab.
Alberto
@AlbertoMantovani Please check your inbox, thanks.
Can you please send me the latest firmware by PM? I believe the latest should be 404XZ0D0.bin.
Thank you!
- 234 Nebula Ideas
- 6.7K Security
- 700 USG FLEX H Series
- 366 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 114 Security Highlight
