Where can I download Firmware NWA-5123ac
Sjaak
Sjaak Posts: 2 image  Freshman Member
edited May 2024 in Wireless
I can't seem to find a firmware download for the NWA-5123ac accesspoint, the FPT server I'm being directed to does not seem to contain the firmware. Is there a legacy firmware FTP server?
  • Sjaak
    Zyxel_Jay said:
    Hi @Sjaak
    Here is the NWA-5123AC latest firmware.
    610AAZY10C0.bin
    You can download this firmware.
    Here is the step you can upgrade the firmware by the local GUI
    Connect your computer to the AP using an Ethernet cable.
    Access the AP's web-based configuration page by typing its IP address into a web browser and logging in with the administrator username and password.
    Navigate to the "Maintenance" or "System" tab on the configuration page.
    Find the "Firmware Upgrade" or "System Upgrade" section and click the "Browse" or "Choose File" button to select the firmware file that you downloaded in step 1.
    Click the "Upgrade" button to begin the firmware upgrade process.
    Wait for the upgrade process to complete. This may take several minutes. Do not interrupt the process or power off the AP during the upgrade.
    After the upgrade is complete, the AP will automatically reboot. Wait for it to come back online, and then log back into the configuration page to verify that the upgrade was successful.
    Let us know if you have any questions.
    Jay
    Thanks for the reply Jay,
    I've got the file, thanks allot!
    Kind regards,
    Sjaak
  • Zyxel_Jay
    Zyxel_Jay Posts: 226 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    Hi @Sjaak
    610AAZY10C0.bin
    Jay
  • Sjaak
    Zyxel_Jay said:
    Hi @Sjaak
    610AAZY10C0.bin
    Jay
    Kind regards,
    Sjaak
