DNS
Hi everyone, I can't get my.name.it to point to the internal network address 192.168.x.x. I compiled the dns but it doesn't work. from outside the network instead typing my.name.it the correct client replies and everything works correctly. Can someone please help me to solve the problem. thank you very much
    PeterUK Posts: 3,993  Guru Member
    Sounds like NAT loopback? Does the NAT rule have that enabled?
    NAT loopback only works if the USG has the WAN IP
