confused with zywall models usg60 / usg100 / usg20
asiawatcher
asiawatcher Posts: 6 image  Freshman Member
edited February 2023 in Security
Hi there guys, which model is newer usg60 or usg100 ?
usg60 GUI and speed looks much better and faster than usg100 even after firmware upgrade
how about USG20 ?? newer or older than the usg100 and usg60 ??
thanks
Best Answers
    PeterUK Posts: 4,608 image  Guru Member
    The USG60 is the newest but is EOL as is USG100 and USG20 unless its the USG20-VPN which is slower then the USG60.
    Best to go by the SPI and what listed by the site to not get a old model
    how about usg100 and usg20 which is the slowest and oldest
    not sure which is oldest but the USG20 is slower
  • mMontana
    mMontana Posts: 1,498 image  Guru Member
    hi thanks for your reply how about usg100 and usg20 which is the slowest and oldest of the 2 ?
    If USG20 is this device.
    is not older but is slower than USG100.
    Instead, if USG20 actually is this device
    actually is USG20-VPN, which is newer and probably faster than USG100 but have less features and is still supported by Zyxel with newer firmwares (as USG Flex 50)
  • mMontana
    edited February 2023 Answer ✓
    AFAIK no. However USG20-VPN is still supported, USG60 no.
    For comparison, you can look up for specs table about the features of all the models..
    USG100 is certainly slower than USG60 (which mostly replaced it)
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    USG20-vpn also known as FLEX50 is next-gen product. It is newer than usg60.
    But USG60 is faster than USG20-vpn
    However, the most important is that USG20-VPN still supported by Zyxel and USG60 had been End of support.
  • asiawatcher
    hi thanks for your reply how about usg100 and usg20 which is the slowest and oldest of the x2 ? I'm very confused with the model numbers.
    cheers
  • mMontana
  • asiawatcher
    usg20-vpn is newer/faster than usg60 or same year ?
  • mMontana
  • WJS
