GS1910-24 VLAN
Hi @Onur,The port VLAN configuration of Sophos firewall connecting port is recommended as below:1. Port VLAN should be "1" if your management VLAN is 1.2. Egress tagging should be "Untag port VLAN".3. Allowed VLAN should be "1,4"Also, the port VLAN configuration of end devices connecting ports are recommended as below:1. Port VLAN should be "4".2. Egress tagging should be "Untag port VLAN".3. Allowed VLAN should be "4"Hope it helps.0
The cable from the firewall is plugged into port 24. The computer with Windows is plugged into port 2. Management port is in vlan1.but windows computer is not getting IP
problem is solved. The problem was caused by the dhcp distribution being turned on.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
