VPN - Authentification with ADD
Omnisoftory
in Security
Do firewalls support Microsoft 365 AD authentication when connecting to a VPN?
Instead of creating all users in the firewall.
Best regards
Damien Vonlanthen
Hi @Omnisoftory ,
Greeting Forum, Azure AD used SAML for user authentication.
Since Zywall doesn't support SAML Auth so it can not be implemented on Zywall.
Thanks your understand.
Kevin
The most easy way is using a middleware Idp cloud to integrate.
Hi @Omnisoftory ,
Kevin
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
