Upgrade from USG60 to Zywall 310 + port role
asiawatcher
asiawatcher Posts: 6
image  Freshman Member
edited May 2023 in Security
Hi all, can i remove the first few lines from a usg60 saved configuration
! saved at 2023-05-10 18:28:09
! model: USG60
! firmware version: 4.73(AAKY.1)
and import this to a zywall 310 or usg310 ? some of the settings at least like mad addresses vpn's and the like so i wont have to redo it all over again ?
Also 310 doesnt support port roles? can i not make all ports except the first wan port belong to lan1 for example ?
thanks
Best Answers
    PeterUK Posts: 4,841
    image  Guru Member
    Zywall The 310 does not support port roles but configurable ports you can't just change the model in the config to make it work.
    You would need to be skilled to edit the interfaces
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,591
    image  Zyxel Employee
    Hi @asiawatcher ,
    Please set it up from scratch. There may be unexpected issues if you import a USG60 cfg file to a Zywall/USG310.
    image  Guru Member
  • Zyxel_Cooldia
    Hi @asiawatcher ,
