log index usg
Filippo
Filippo Posts: 15
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
image  Freshman Member
edited April 2021 in Security
is it possible to have a description index of the system logs of the usg? :)
Best Answers
  • Alfonso
    Alfonso Posts: 257
    image  Master Member
    Hi @Filippo
    I have never seen what you are requesting, but I am sure that mods, or other forum users can give to you more information.
    What I usually do (when I do not have the description of the logs) is sending all the logs to a syslog server, and using ELK (Elastic Search + Kibana) analyze logs.
    Best regards
  • Alfonso
    Alfonso Posts: 257
    image  Master Member
    Hi @Filippo
    Best regards
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,499
    image  Zyxel Employee
    Hi @Filippo,
    Can you give us more details about the request "description index of the system logs"?
    Does it mean you'd like to know the meaning of each log/message?
  • Filippo
    Filippo Posts: 15
    yes, I need to know the meaning of some logs, like this:
    info,ike ,IKE_LOG, Tunnel [Vpn_To_Respighi_Wan1:Vpn_To_Respighi_To_Wan1:0x10ac8b72] rekeyed successfully
    info,ike,IKE_LOG,Tunnel [Vpn_To_Respighi_Wan1:Vpn_To_Respighi_To_Wan1:0x91d96ef0] is disconnected
  • Filippo
    Filippo Posts: 15
    OK thanks
