SSL VPN not working
Hi Alfonso,There are no clients reachable... I tryed almost everything but nothing will work...0
Hi @StevenB,
We fix some SSL VPN related issues in the latest firmware.
The firmware is sent to you via private message.
Upgrade your USG60 to this version and check if SSL VPN client is able to reach devices in LAN1.
Hi. I have the exact! same issue. Also tried upgrading the USG60 to latest FW v4.32(AAKZ.0) with no luck...0
Hi @Franki80
This issue is fixed in latest firmware,
The latest firmware will be sent to you in the private message. Please check your inbox.
Hi a have same problem on USG20-VPN - firmware 4.32 (ABAQ.0). Is there a firmware fix for this model?0
Hi.
Newest firmware fixed it for my USG60W.0 -
Hi @ZdenekB
The latest USG20-VPN firmware will be sent to you in the private message. Please check your inbox
- 603 USG FLEX H Series
- 481 News and Release
